That said, you could try combining a GPU-only block and tack on some simple heatsinks to cool the RAM and VRM's (just make sure you have airflow over the VRM's).
That's because those heatsinks on the VRMs are way too small for the heat they output. You have to make sure your heatsink can adequately dissipate the heat put out by the chip while maintaining a reasonable temperature delta with the surrounding air. I remember that the VRMs on my 4870 used to put out insane amounts of heat, I doubt the ones on the 4890 are any better (and are probably much worse). Try tacking on a very large heatsink that bridges all five of them, or using the stock backplate in combination with the GPU waterblock (if it fits).No, that doesn't work.
Here's what I did to my 4890 before slapping on an EK VGA-Supreme GPU-only block.
*snip*
Unfortunately, it doesn't work. The VRM overheats rather quickly and crashes the entire system.
I'm back to the stock hsf now while waiting for the arrival of my EK full-face block.
Looks great@ Mr. K6, thanks
I've just installed a full-face block and it is now working great
@ Mr. K6, thanks
