- Aug 24, 2006
Is it safe and advisable towash TRUE 120 with water? The dust mounted inside its nets is hard to get rid of?
I wouldn't recommend the dishwasher. Salt could corrode it if not adequately rinsed, and the water jets could deform the fins.
I wouldnt wet any CPU cooler metal (that can corrode) with water unless the corrosion can easily be removed.
The cooler is reliant upon good air contact, corrosion adds a thermally resistive layer which slows heat transfer.
This is worse with certain detergents.
As pointed out above, the salts in dishwasher detergents will cause worse corrosion.
The only time it may be worthwhile is if you cannot remove surface grime and it is causing a big drop in performance.
All my aluminium finned coolers I have owned are aluminium with no nickel plating.
All those I see for sale have aluminium fins with no plating.
i dont recall ever seeing a CPU cooler with nickel plated fins.
Yes, but that has nothing to do with the price of fish.Xigmatek Dark Knight, TRUE Black, just about every heat pipe in every cooler is nickel plated.
The discussion is about the use of detergents as well.Fins on most coolers are not plated, but aluminum doesn't corrode very easily in water. You'd have to leave it in water for a substantial amount of time to do any permanent damage.
Why not just wash it with alcohol? Its not exactly expensive. I used to wash my "glassware" with Everclear....amazing what kind of sticky residue it can get off![]()
yes it even removes the smoke off the water.... I remember those days
