Washers on Motherboard
note235
Some motherboards come with washers like the red circle
do i need to use these or will screws just be okay?
They arent really washers, but more so gasket type material.
You should be fine without them as mentioned above.
The screws should be fine if you're using a fairly newer mobo/case.
No and dont use them even if free. They are a holdover from the bad old days when motherboard manufacturers would run traces right next to the screw mounting holes and were used under the heads of the motherboard hold down screws to prevent shorting to the traces.
Look at your board, look at the mounting holes, see the circles with big pads, notice that there are no thin straight circuit traces next to the holes, its all either clear of all solder or has larger "blobs" of exposed solder kinda arranged in a circle or "target" pattern. This is for grounding.
Boards made in the last 5+ years are made to have the screw heads touch the ground pads around the hole to help ground the board to reduce EMI and in general provide stable opteration.
DO NOT USE WASHERS, it will prevent proper grounding.
Install a couple of screws but NOT TIGHT, adjust the board so that all the rest of the screws go in loose and adjust again so all screws are centered in the holes as much as possible. Check that none of the metal "fingers:" on the I/O backplate have gotten inside a connector. Snug down a couple of screws at opposite sides of the board while you hold it to keep the board from shifting. Check your scew alignement and if all looks good snug the rest of them down. Do not crank down hard, smartly snug is all you need you do not want to crush the printed circuit board.
