Warm? Apple iBook G4 $220
panfist
Newegg has an upcoming shell shocker for an Apple iBook G4 for $220. I was wondering how it compared to an atom-based netbook. If the performance is about equal, then this could be a nice deal. I was thinking of getting a netbook, but I might get this instead.
edit: I think the biggest knock against this will be the 1024x768 screen resolution: most newer netbooks will have a much higher resolution for the same sized screen.
It's heavier, it's using older tech, there's no prospect for a modern operating system and the software associated with that...
It's probably a little faster than a netbook, but the pre-intel OSes will not play well with a lot of current software and do not have a future. It's also 2x as heavy and any supporting or replacement parts will be more expensive (apple/harder to find).
Yeah, I'm thinking I will pass on this. For some reason, I thought Ubuntu had continued PowerPC support later than 2008...
FYI on OS X Leopard I remember this could barely play youtube videos and I had maxed ram (1.5gb). Definitely plan on using OS X Tiger if you're gonna get this.
Leopard will NOT install on G4 machines. You can "modify" the installer to force it to install anyway (involves changing some digits which disables the installer from checking system requirements), which is what I did on my iMac G4, but I can tell you right now it's absolutely not worth it. 10.5 Leopard ran like shit on my iMac G4. There's a reason they cut off the G4. It was a great machine and processor in its' day, but that day is long gone.
Nifty deal if you have nostalgic feelings toward these machines and don't mind parting with $200+, but not really worth it otherwise. I could see these being nifty machines to install OS 9 on and mess around in there, but even then...meh.
Yes it will. The only time you cant install leopard on a G4 is if the ram is less than 512mb. Or if it doesn't have a dvd drive. Either way I can confirm that Leopard will install perfectly on the iBook talked about in this thread, no trickery required. Although whether you would want to or not is a whole nother story lol.
Will this run Final Cut Pro? My brother is bitching that he needs a mac for college and wants my parents to buy him one... :p
EDIT: Probably not, looks like it doesn't even come close to the minimum specs :p
DON'T BUY A G4 MAC
If you want a cheap Mac, get a 1st gen Intel one. The extra $100 is well worth it as at least it won't choke while attempting to view modern websites.
DON'T BUY A G4 MAC
cheap and Mac in the same sentence? Unpossible! :eek: I've been looking for a inexpensive Mac mini and most of what I see on the lower price range is G4 crap.
Heh, I got a G4 Mac a month ago for $20 because it was listed as broken but just needed a nvram reset. I still have no idea what exactly to do with it though. I basically used it to learn the OS layout so that I could provide support when needed, but there is pretty much zero software available for a dead architecture. I think Leopard runs pretty decently on it, but it was the higher end 15" model. Still, no way I'd pay much at all for one. At this point its pretty much just useful for a very basic web browser.
It isn't even worth it for that because of the amount of flash used in modern websites.
Flash + PowerPC = Fail
