Want Opinions On Reasonable RAID Setup
therock
Hi Guys,
I am at a setup point and would like your thoughts. I built my system and have ran both the onboard RAID controllers and seen no difference between the two in speed or stability but don't really know how to test them. I have never used a RAID controller Card.
My Application:
A home PC User I'm a photographer and process lots 15.1 MP image files in Adobe's Photoshop CS4 and Canon's Digital Photo Professional. I want to run a booting to OS RAID 1 setup so I can keep going if I have a single drive failure.
I also have an eSATA external box by XTRASTORE with two WD RE2 drives in RAID 1 as a backup using Genie soft's 8.0 Pro.
So as is I am running my system on a WD Green (slow) 750GB drive. It says 5400/7200 but I see no evidence of it ever spinning up to 7200. My mistake it will be going into a MyBook USB box soon.
I now have two WD RE3 750GB drives ready to take Vista 64bit and go into a RAID 1 setup. I want to pull all of my peripherals and start fresh loading all my programs again. Fun Huh?
So you guys knowing how my system is now, how would you go about starting to convert?
And do you think a controller card is needed?
And do you like the Gigabyte or Intel onboard RAID?
My Specs:
Gigabyte GA-EP35-DS3R
Intel Q6600 Quad
8 GB Corsair RAM
620 Corsair PSU
Vista 64 bit home premium
Current HDD Setup:
* Running OS on a WD 750GB Green. Big mistake with the 5400/7200 rpm thing.
* External eSATA XTRASTORE box in RAID 1 For Data and photo backups. Two WD RE2 750GB drives.
For RAID1, onboard RAID is more than enough. AS for which RAID controller to go with, I'd say Intel simply because I haven't seen the Gigabyte RAID in action.
Thanks,
I was thinking a $300.00 + controller might be a bit overkill for my application.
