Hi, the motherboard has no vertical sata pcm mounts, instead it has angle ones. See the photo attached:
http://darkbasic.homelinux.com/images/P1010979.JPG
The problem is I have to mount a 6 HDD cage in front of the sata ports and there isn't enough space
I can't mod the case (it's a yeong yang rack 4U) because on the other side there are two fans and there is no space left to shift the cage.
See the second photo:
http://darkbasic.homelinux.com/images/P1010980.JPG
What can I do? I can't use angle sata connectors because I need all 6 sata ports (I can use only 3 ports with angle connectors).
Thank you,
Darkbasic
Thank you,
Darkbasic
