XxDaRkReAp3rxXdOtCoM
My User Name Is Stoopid
- Jul 27, 2005
Finished my 1st build. Took 6 hours total doing everything. Wiring SUCKS ASS I KNOW but its the best I could do.
GeForceX said:What the hell? It looks like an octopus got strangled by a fan and been left there to die.
-J.
XxDaRkReAp3rxXdOtCoM said:cuz it was my 1st build so I was being super careful and windows took an hour 2 set up. Meaning format and install.
Spectre said:Formatting and installing the OS usually takes far longer for me than the physical building a system.
AcidTone said:just wondering what type of case is that?
XxDaRkReAp3rxXdOtCoM said:Are you 15? Was that your first build? Were you being extremely careful??.... Exatly my point. O ya, BTW, you probably know a lot more about computeters than I do so thats why.
Spectre said:I wasn't dogging you.
XxDaRkReAp3rxXdOtCoM said:I was proving just proving a point.
Spectre said:Maybe I should put it this way. Don't worry you will get to the point where formatting/installing an OS is the longest part of a build.
J-M-E said:heh...Im 15, first build took about 45 minutes (not including windows install), that was when I was about 13 however.
yea wiring needs some work
Welcome to the club![]()
Borgschulze said:I was 13 too when I built my first rig.
Took about 10 minutes to set it up, because I built is out of case because I couldn't afford a case.
New computer I built last week, and I'm now 16.. took about an hour, I have awesome wiring, but it could be better... but I'm not going to waste time with a dremel.
O/S on this beast... already installed on my old HDD... upgraded from nForce 3 platform, so I just booted safe mode and installed nForce 4 drivers and it worked fine...
qbackin said:Welcome to the addiction. It has only begun.
