aznx said:On. People that have it off and have a LCD are retarded.
Adionik said:Hm. I guess i'm retarded. What does it do again? And won't you take a hit in FPS?
Lazy_Moron said:Really? I always keep it off and never experience tearing on my LCD! So am I retarded?
Anyways ignoring his ignorant post, if you experience any kind of tearing, then turn it on. Though when turning it on, you may have a decrease of your FPS. Depends on what card you have and how demanding the game is. For me, I keep it off, as I never experience any kind of tearing on my LCD, so why lose some FPS when you dont need it?
Before you makeanother ignorant post, where in the hell did you pull 200 and 60 from?aznx said:Maybe your eyes are slow, or depending on the game, you won't/hard to notice.
Does it REALLY matter that you're getting 200fps instead of 60fps on a LCD monitor? Not really.
bLaCktIGErs91 said:Before you makeanother ignorant post, where in the hell did you pull 200 and 60 from?
lodingi said:thanks for the responses. does more fps benefit you during multiplayer game play?
Hi. Like others have said, it is not a definate plus unless you can actually identify the tearing. finding it depends on your monitor and other smaller facors like contast and sharpness (from my experiences).lodingi said:hello everyone. i was wondering if it's best to have vsync on or off during gaming. i would appreciate your coments.
Krayzie135 said:
Juic3 said:Add me to the retarded list, dont really notice tearing a lot. The performance hit is just too big for me to put it on.
aznx said:Performance hit of what? If your monitor can't display it, it doesn't really matter if your videocard is rendering it or not.
lodingi said:great info everyone. thanks again. what is the advantage of using a higher resolution when gaming? i am using a mitsubishi diamond pro 2060u. it can handle 1600x1200 @ 85hz.
Lord_Exodia said:Depends on the game. If I'm playing competitively or a game where fps really matter I disable vsync. If I'm playing a game that is slow paced and more about eye candy then I turn it on.
E.G. Unreal 2004 = Off
Doom 3 (offline)= On
lodingi said:so do more fps = better online gaming?
But with VSync on, if you're at 60 fps and then the frame rate drops, it doesn't just drop a few frames: it goes straight down to 30 fps!!Oline61 said:Doom 3 is capped at 60 FPS internally, so unless your refresh rate <60hz then you should turn VSYNC on, because you will incur no performance hit.
