Oldie
Mean Old Administrator
- Jan 12, 2004
Here's what I've got:
8/3 internet connection via Comcast on a Sci. Atlanta DPC2100 Modem
VTech IP 8100-2 Vonage adapter
Linksys WRT54G v.5 Router w/series 1.0.0.6 firmware (current)
The hookup is modem->router then split to PCs and IP8100
Here's my problem:
I use Cisco's VPN client (v. 4.8.00.0440) for access to my office, and whenever I have the vonage device on the network, I can connect, but not get anything across it (exchange, RDP, NT Drives, etc..). I'm thinking it may be a port conflict, but I have no idea if I'm correct or how to resolve it.
The Cisco client requires port 10,000 TCP, while the VTech requires 10,000-20,000 UDP. Because I couldn't route the same port to two devices, I placed the VTech into the DMZ, and forwarded 10,000 to the PC I use for office work.
I'm sure it's not the most common setup on earth, but I'm hoping someone has experience with it. I appreciate your taking the time to read either way. I've also posted in the Vonage forums, but I figure a lot of you have experience specifically with Cisco VPN software.
Here's my problem:
