lawrence131
- Feb 23, 2005
I picked up the $78 Fry's combo for mobo and Pentium D 805 but forgot that it was OEM so no HSF. My HSF won't arrive till Thursday so I decided to do a stupid experiment....
1. Cover bottom of ice cold vodka glass with aluminum foil in hopes the water will condense on the TOP side of the foil.
2. Apply thermal grease to bottom of foil and CPU.
3. Take a swig of Vodka and push POWER! (or rather short the power jumpers with a piece of metal for a split second since the power_switch cable isn't plugged in
So what can an ice cold Vodka accomplish?
1. It'll let you POST, check out BIOS options, even attempt to OC.
2. It'll START to load Windows.
3. Then it'll corrupt your boot partition beyond repair
Good thing I backed up before mobo/CPU swap anticipating need to reformat. After I corrupted my boot partition, I rebooted into BIOS again to check out temps. CPU temp =112C and rapidly rising on Vodka cooling =) Cheers!
BTW, I didn't think glass would conduct heat away from the CPU like copper does and with no flow even an ice cold block of copper probably wouldn't work for long, but guess I was bored. At least nothing fried that wasn't meant to be reformatted anyways.
