VNF3-250 Problem! Help Appreciated
D4xL0ki
Hi all. Haven't posted in ages. Anyhow, this problem is driving me nuts and any help would be appreciated.
I have a Chaintech VNF3-250 Mobo that gives me one of 4 errors upon booting up:
1) Blank screen and repeating long beeps. 2) "Keyboard error or no keyboard present" 3) "bios chekcsum error" 4) Normal bootup code but screen has artifacts and is all messed up
Sooo...error#1 led me to test my RAM. I have 2x512 Corsair value PC3200 and I isolated each module in different slots, tried different combinations, etc. None of them worked.
I switched video cards around and also PSUs to no avail. So I thought this is something Mobo related.
I also double checked to see if any of the standoffs was shorting out the board but this was not the case (using 5 of 7 standoff spots).
An odd solution was found when I found out that I would get to windows by running the entire computer on its side. However, when I get to windows, the time and date are all messed up, which leads me to believe its possibly the CMOS battery. But why would the computer work on its side and not running straight up? :confused:
If I try to run the computer straight up, back to the errors!!! :mad:
Here are my other peripherals:
Antec TP2 480 PSU, 2x512MB Corsair value, AIW X800XT, 2 Hdd, Opitcal, floppy, 3400+ with XP-90.
Everything was running fine until this weekend WTF!? BTW I also reformated (thanks Ghost).
Hope your weekend was more eventful than mine. Thanks for any info or help. :)
If it runs while being in a different physical spot, I would imagine it is still a shorting problem even though you noted the standoffs aren't the problem. Take the board out and run it on cardboard to see if it works outside the case. Also, I'd get a new battery anyway.
OK, so I removed everything outside of the case and booted up. It works. Also, I can still boot with the case sideways on my desk and the computer will work flawlessly.
But if I tilt the case to its straight-up position while using Windows, the system freezes and then I have to reboot (with the case sideways :mad: )
I am using an Antec P160 case. All the standoffs are in the right place. I just don't get it. If this is a a short, where is it coming from?
Also, I notice the USB ports are acting funny. I have to replug my keyboard and mouse sometimes upon booting up.
Could this MoBo just be screwed up somehow? What am I doing wrong?
