VM problem
gnewbury
[H]ard|DCer of the Month - September 2007
Just tried to install VMware on the new Dell 530 Q6600 w/ Vista Home Basic. It's my first VMware install.
At what appeared to be the last step the machine rebooted (without asking), and continued to reboot. I went to the restore point before VMware and it seems to work now, but w/o Vmware.
Any suggestions to get it working?
I've only 1GB at the moment, was just trying to see how the load works while I wait for the other 2gb to come in.
BillR
Born Again Cynic
Make sure under your CPU settings in the BIOS you have Virtual Machine turned on. It won’t run without that setting.;)
Killer[MoB]
[H]ard|DCer of the Month - March 2008
Note that some bios's may list this in different ways.
These are the two I have seen.
  • Vanderpool Technology
  • Virtualizaton Technology
May also be IVT (Intel Virtualization Technology)
aldamon
Is this UAC rearing its ugly head again? Disable it, install VM, and then re-enable it.
Tigerbiten
[H]ard|DCer of the Month - February 2007/January 2
I found that to get VMWare Server to work under Vista, I had to turn off "Only work with Signed Drivers".
Hit "F8" at the end of P.O.S.T. to get into that options menu.
Its why I stopped useing Vista and have gone back to XP.
Luck ............ :D
