Sep 4, 2009 #1 S Sayte n00b Joined Sep 1, 2009 Messages 11 I have an Iomega 1TB USB drive connect to my Vista (x64) Ultimate PC. I have to manually power OFF and then back ON for the PC to recognize it. This occurs even after rebooting. It works with XP fine. Any thoughts?
Sep 4, 2009 #2 O Old Hippie Supreme [H]ardness Joined Oct 31, 2005 Messages 6,013 You probably need to enable AHCI.
Sep 5, 2009 #3 N necrophile [H]ard|Gawd Joined Sep 6, 2008 Messages 1,243 I had to do this for an E-sata flash drive I bought although usb connection for it worked fine. Still give it a try.
Sep 5, 2009 #4 S Sayte n00b Joined Sep 1, 2009 Messages 11 I tried this and rebooted, but still have the same issue. I set the DWORD back to 4 (as it was). I think you may be on the right track, though. If Vista is not enabling drivers by default, then it should be a relatively simple fix.
Sep 5, 2009 #5 N necrophile [H]ard|Gawd Joined Sep 6, 2008 Messages 1,243 Do you have any other usb devices like mice or what not that work when plugged in when the comp is on?
Sep 11, 2009 #6 S Sayte n00b Joined Sep 1, 2009 Messages 11 I have a Logitech USB mouse, but it loads just fine.
