Dumass_Freakboy
- Dec 20, 2000
I've been trying to get xp installed on a second partition from a pre-existing vista installation. It's installed on an lenovo X61s with no cd/dvd-rom drive. I do not have access to a cd/dvd drive via usb or docking bay, and want to get this working without if i can. I do have a usb floppy i bought a year back, and have had limited success.
I have already shrunk the vista partition, giving myself 8gb free space. i created an 8gb fat32 partition, and copied a legit version of xp onto it. used a floppy disc to get dos access... and in turn ran the winnt install from the i386 directory.
It runs through the whole dos portion, then says to remove the floppy if one is in the drive, and press enter. i do so, & it reboots to the loading vista screen... i've tried a few other copies of xp i have that aern't legit, and same results - it just doesn't touch on the gui portion of the xp install & simply loads vista
anybody have any idea what i might be missing? I've been searching all over google, but nothing i type in seems to bring back any good results
