How about XP Pro?
All versions of Windows XP and Windows Vista can address all four cores on a quad core processor.
That's what I thought. Figured I'd better ask though.
Vista, the new Windows ME.
Vista . The only downside is its hardware requirements.
And the fact that some software will not install or run. Also, the fact it is prone to crashing constantly. Yes the dreaded BSOD is back. ( I have never gotten a BSOD in XP.)
Most crashes are caused by poorly written drivers and that goes for all OS's. And to anwser your some software will not run or install, it's not MS fault that companies can't port or write software well for the OS. I find that most users that complain about crashes pretty much have limited skills when it comes to messing with new OS's and computers in general.
As for drivers, the hardware companies should not be releasing products if they dont work with the OS. (The laptop I bought was ONLY available with Vista.)
As for the software, how would the developer of a program write it to work with Vista in 1997?
Failure of MS to offer compatibility in my book.
QFT, God I am so tired of posts claiming that Vista sucks. Vista is the best OS I have ever used hands down. I really enjoyed tweaking until things purred like a kitten. In all fairness , i dont use any software that is prehistoric so may be thats why
you QFT my post only stated the reasons for most BSOD.
Really? I havnt got a single BSOD from vista. It runs SMOOOOTH!![]()
Same here, i never got a bsod in vista either.
Yes software does need to be replaced. IF, there is a replacement available.Have you ever stopped to think that any software that will not install (or run) in Windows Vista (despite the compatibility options available) is, quite simply, software that deserves to be replaced? The *only* software that I have had issues installing on Windows Vista are: games that require MS-DOS Mode (not a DOS compatibility box) and Lexmark printer drivers. I have old Windows games (one, Microsoft Fury3, dates back to the launch of Windows 95) that run quite happily on Vista (however, Fury3 is so well-behaved that it runs on *Windows NT 3.51 Workstation*). Newer games also behave quite well (from Bioshock to Enemy Territory: Quake Wars).
What software has been giving you grief?
Vista is called ME by usually 2 people. The ones too cheap to upgrade to a new OS because they are still fine with a 5 year old operating system. Or by those who generally can't build a stable system to begin with. Vista is a fantastic OS some people just need to move on. It's like people ranting about the move from win 2k to XP all over again.
