I'm trying to troubleshoot this one and I'm getting a little frustrated. I think it might be an overheating issue, but I'm not 100% sure.
I built my wife her first actual PC last Christmas (she'd previously only had laptops) and she's just recently gotten into PC gaming (from consoles). When I first built her PC, she was using the onboard video from the A10-6800K APU I built the system with, but it wasn't good for much. I decided to give her the Radeon 5850 2GB from my PC, which had largely gone idle over the past few years.
Lately, she's been playing a game called Ether. She'll play for 15-20 minutes, then get a steady beeeeep that seems to be coming from the video card. The card is definitely hot as blazes. Sometimes, the fan seems to ramp up right as it happens, but doesn't always. It seems to stay at 30% fan speed or so until the beeping.
The first thing I did (after making sure the card and PC innards were clean) was install the MSI Afterburner program and have her manually set the fan speed up when playing. At 60% fan speed (which is the threshold of tolerable noise), GPU temp seems to sit at around 60C (before installing afterburner, temps were around 72C at 30% fan speed).
Now, she can play for about 30-45 minutes before it starts to beep. If she alt/tabs to the desktop, the beeping stops immediately and the temps start to drop. She can then alt/tab back to the game and play for another 15-30 minutes before it beeps again. Still, the temps never seem to spike or anything... it just seems to be after a while of playing, but having the fan speed higher definitely seems to help.
The other thing I considered was maybe the power supply, as I've read these cards can set off the alarm for voltage as well. The power supply is a Corsair Enthusiast Series 80 plus bronze (CP-9020039-NA650W).
Other than that, the PC is pretty empty. It's a NZXT Phantom 530 case (stock case fans), with a single hard drive, 8GB of memory, single optical drive. The case is not inside a cabinet or anything, not that it would fit in one, lol. I've never had the card overheat on me, but then again, I haven't gamed on it seriously in a few years.
Any ideas?
Video card: http://www.amazon.com/VisionTek-Radeon-Express-Graphics-900297/dp/B002QEBGGA
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146106
PSU: http://www.amazon.com/dp/B005E98I0G/ref=pe_385040_30332200_pe_309540_26725410_item
Any ideas?
