- Feb 1, 2005
I'm trying to help a friend with their laptop (Toshiba Satellite, IDE 2.5" HDD). It attempts to boot into Windows XP Home with a Pre-SP2 Splash screen, but blue screens and reboots.
There is nothing important on the drive, so I decide I'll just do a fresh install. I boot off of a XP Home CD and I see a partition however, it won't let me delete that partition or install Windows to the partition. So I figure I'll just try booting using Gparted and delete the partition that way.
I boot up Gparted and see a 10.29GB NTFS partition. I delete the partition and save changes, but it won't remove the partition. When I boot back into Gparted, the partition is still there.
I also tried to pull the HDD and put it in my main machine running XP Pro via a USB adapter, but when the drive is inserted, no HDD tools will load. The Disk Management won't load. The SeaTools for Windows (Seagate drive) won't load. I'm not sure if the hard drive is bad or if there is a virus of some sort that won't let me overwrite the boot sectors.
Any help would be appreciated.
