Videocard for an older system
Status
Not open for further replies.
Mikey20
I have a older system i want to upgrade the videocard for..but i wanted to know which videocard would be the best for this system without spending to much and NOT bottlenecking my system. On this system its mostly Counter-strike. Here are the specs.
Pentium3 500mhz
256mb pc100 ram
10gig 7200rpm SCSI hardrive
windows 98se
(geforce4 mx440se 64mb PCI)
also this mobo doesn't have AGP so i need a PCI card....with this card i still get video studders even with everything turned down to the lowest quality on this gf4mx440 card in CS. what card do you all recommend for this system without bottleneck.
Originally posted by VIOLENCE FACTOR
Your a spammer moron.
1.
Absolutely NO FLAMING OR NAME CALLING, this is grounds for immediate removal of your posting privileges.
2. If you're going to call someone a moron...
I think you can still find the fx5200pci cards around that would fit that system nicely.
CHAINTECH GeForce FX 5200 Video Card, 128MB DDR, 128-bit, DVI/TV-Out, PCI, Model "P-FX20" -RETAIL
- Specifications -
Chipset/Core Speed: Geforce FX5200/250MHz
Memory/Effective Speed: 128MB DDR/332MHz
BUS: PCI
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI connector
Support 3D API: DirectX®9, OpenGL®1.4
Cable/Accessories: S-Video Cable, Driver CD, Manual
Max Resolution@32bit Color: 2048X1536@75Hz
Retail Box (See pics for details)
Model#: P-FX20 128MB
Item#: N82E16814145055
Rating: Vote(s): 3 Review(s): 2
Free FedEx Saver Shipping
Yes $71.99
priced from http://www.newegg.com/app/ViewProduct.asp?submit=property&DEPA=1
and violent factor you sound like the spammer so hopefully a mod removes your sorry ass;)
At least I don't start topic after topic of frickin nonsence asking stupid questions that have been answered a 1000 times over on this board. :rolleyes:
Don't read my topics then easy as that.....i hope you are banned from HardForum. I WILL continue to post "useless topics" as you call them ..just to piss you off :D have a nice day!
Seriously why would you upgrade a 500mhz computer. I would just stick with a voodoo3 pci in there or some cheap 2D only PCI vid card.
Radeon 9100 PCI @ 250/250.
Brent says there is an 8500 PCI running at 275/275, which would kick the hell out of any other PCI card, but I haven't found one yet.
i don't see you contributing anything worthwhile to this thread. any more flaming and you're gone
and if you do that, you'll be banned also. do some research before you post
Status
