Video editing workstation / hackintosh build, advice please?
Status
Not open for further replies.
Kirika
Video Editing primarily with some 3d work and hosting Virtual machines because that 24 bay Supermicro dual opteron I thought was such a great deal is too darn loud. Premiere Pro, After Effects, Maya, Photoshop, Illustrator. VMware Workstation. Hackintosh for Final Cut Pro. Some games Battlefield 4, Diablo 3. Star Citizen in the distant future. Folding for the Horde when I'm not using it for any of the above.
Whatever it costs rather not spend more then around $2000 for everything else not including Motherboard, CPUs and Operating System and OS SSDs since those have been ordered or have them already.
New Jersey, United States
Case, RAM, PSU, blue Ray burner, Cooling, SAS Raid card, SSDs for Raid Array,
Maybe AMD HD 6950 video card(worth holding out for 790, 870 or 880?)
Maybe 2 WD Black 2 tb raid 1 for data.
6) Will you be overclocking?
No Xeons are locked and this is a work machine.
Two 24 inch Dell 2412M 1900x1200 each. Considering getting a 3rd for Surround/Eyefinity but I don't play that much Battlefield and video cards to support are pricey with little work benefit plus I would need a new desk. Only game on one screen.
Next week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Already selected Motherboard but reliable dual socket motherboard with USB 3. Firewire. I like to use add on raid cards so will not be using onboard raid.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Have Windows 7 Pro 64 bit license and OSX license to use.
Items without links/price I already ordered or have on hand.
Case
Antec Ninteen Hundred $186
http://www.amazon.com/Antec-Ninteen...826916&sr=8-1&keywords=antec+nineteen+hundred
Holds 12 hds hopefully don't need more the that. Current machine has 10.
Power Supply
Seasonic 1000W Platinum $304
http://www.amazon.com/Seasonic-PLAT...19821&sr=8-1&keywords=seasonic+1000w+platinum
OR
EVA Supernova 1000w Platinum. $207
http://www.amazon.com/EVGA-SuperNOV...19883&sr=8-1&keywords=evga+supernova+1000w+p2
Might have to look elsewhere other then Amazon because they are showing weeks for shipping for both models and I want to get this up and running soon.
Processors
2 x xeon 2680v2
Motherboard
Supermicro X9dai
CPU Cooler
2 x coolermaster hyper 212 heatsinks $33.24 each
http://www.amazon.com/Cooler-Master...-1&keywords=coolermaster+hyper+212+heatsinks,
Memory (RAM)
32 gb 4x 8 gb crucial ecc ddr 3 2x $219.99 for a 16 gb kit.
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=F55B8CFCA5CA7304
Pricey but guaranteed to work and lifetime warranty. Should I be looking at other memory?
Hard Drive (HDD)
OS SSDs
2 Crucial M500 250 gb (1 for Win7, 1 for OSX)
Samsung might be faster but I just ordered these off the Hot deal.
Data drives
2x WD Red 4 tb $184 each
are these reliable or should I be getting blacks. I get 1 whole tb more for same price but 2 years more warranty on blacks sounds good.
http://www.amazon.com/Western-Digit...=UTF8&qid=1394830218&sr=8-1&keywords=4+tb+red
OR
2 x WD Black 3 tb (raid 1 for data) $192.99 each.
http://www.amazon.com/Western-Digit...13&sr=8-1&keywords=western+digital+black+3+tb
OR
Could just use the 2 tb blacks in my current machine. They aren't full.
Optical (Disc) Drive (CD/DVD/HD-DVD/BR)
LG Electronics 14x SATA Blu-ray Internal Rewriter without Software, Black (WH14NS40) $57.79
http://www.amazon.com/LG-Electronic...=UTF8&qid=1394740979&sr=8-1&keywords=WH14NS40
Video/Graphics Card (GPU)
Reuse HD 6950 planning on holding out till GTX 800 series. AMD pricey right now beause of miners. How much is this 6950 holding me back on Battlefield 4 1900x1200? Nvidia card for cuda would be nice.
Sound Card
Is it worth getting a sound card? If so is soundblaster still the card to get? I have an old Soundblaster Audigy 2 with front panel so been out of it. I used to hook up my keyboard to the front bay of the soundblaster to record my music but I haven't done that in like a year since my soundblaster is on the fritz.
RAID controller
Areca 1214 4i $300
http://www.ebay.com/itm/areca-ARC-1...sk_Controllers_RAID_Cards&hash=item46152b7f0f
found out the LSI's don't work in hackintosh.
RAID Array for video and virtual machines.
2 x Crucial 480 gb $219 each on Amazon.
http://www.amazon.com/Crucial-2-5-I...=1394827040&sr=8-1&keywords=crucial+480gb+ssd
Any suggestions welcome please. Looking to order everything next week.
I would inquire at http://www.tonymacx86.com/home.php
They are very keen on certain manufacturers of parts that are directly compatible with the mac clones you are trying to build. The information available on exactly what to buy to get one working right the 1st time is key. I inadvertently bought then hacked instead of studying 1st then getting it to work and it cost me months of learning and heartache to make it work, but if you buy the recommended parts then setup is beyond easy.
Pretty much you don't really want to pick random parts like I did you want to buy exact part numbers.
Discussion of Hackintoshes not allowed here. Thread closed.
Status
