Video card upgrade for old machine
Should give a nice 40% GPU performance boost over a stock 8800GTX. The only stumble block is if your PSU can handle the additional 10-20 watts it will pull :)
I have a 550 power plant running in it so I'm assuming it should be ok.
Heh. It just struck me. That card has 1 Gigabyte of memory, my first had 1 megabyte :eek:
Not really. Not all 550W PSUs are the same and are capable of providing enough power for a card like that. So what 550W PSU do you have?
Rosewill Performance RP550V2-D-SL
It's GOOD RUNNER!
Model RP550V2-D-SL
Type ATX12V v2.01
Maximum Power 550W
+12V 2 Rails
SLI Support Yes
Fan Silent Dual 80mm 2-Ball-bearing Blue LED Fans
Main Connector 20+4-pin
PCI-E Connectors 2 x 6-pin
Modular Cabling Support No
Power Good Signal 100-500ms
Hold-up Time >16ms
Efficiency >72%
Input Voltage 115 / 230 V
Input Frequency Range 47 - 63 Hz
Input Current 10A / 5.5A
Protection Short Circuit Protection
OVP-Over Voltage Protection
OCP-Over Current Protection
OPP-Over Power Protection
MTBF 100k hours at 25°C, max. load, nominal input
Approvals UL, FCC, CE, TUV, CSA
Dimensions W x H x L
150 x 86 x 140 mm
5.90" x 3.39" x 5.51" inch
Warranty 3 Years
It's GOOD RUNNER!
BAD CHOICE.
Ignoring the fact that Rosewill isn't one of the better quality PSU vendors, most of your PSU's power is on its 5V rail, whereas today's components draw most of their power from the 12V rails. 35A is also on the low end of a power supply that has at least 500 watts -- I know of a couple of quality 400W-450W power supplies capable of that.
If you've had that power supply for over two years, I recommend getting a new one -- especially if you're looking at the HD4870 as a replacement video card. The Corsair HX/VX/TX series, the Antec Earthwatts line, the BFG LS/ES series, and/or any power supply from Seasonic, Enermax, or PC Power & Cooling would work.
BAD CHOICE.
Bad choice......Seems run my machine pretty damn good. If I have to upgrade it then for sure I'll just wait until I do a total overhaul of my PC.
Ok... thanks guys! :p
I'll just keep my 8800GTX for now......It plays my games just fine for now.
For now anyway.
So I concur with Tiraides: Upgrade your PSU when you upgrade the GPU or don't bother upgrading at all. Not worth the risk to your hardware to have a crappy PSU like that.
