Video card not connected?
When I restart it won’t load windows. Depending on 'its' mood it will go to a black screen that says, "No cable connected to the video card, see 'getting started' manual". Other times it will go to the screen where I have to select if I want to boot in safe mode with or w/o networking, or regular windows. Other times it will say "Over clocking failed" then something about the BIOS.
This just started a few weeks ago... I think about the time I download an updated driver for my gfx card (ATI RADION X800); however, sense then I put in an older driver... it didn't fix the problem.
If I want to boot windows, I generally have to restart it a few times for it to work. Then when it does work and windows is loaded the "found new hardware wizard" pops up.
My computer is not over clocked and the cables are connected correctly.
What are the specs of your PC? Is it an Asus mobo?
Yes it's an Asus mobo... I’ve had it working for a year, at least, so everything is hooked up right. Just now I'm having trouble.
