Video card Issue 8800gtx
JKownz
I randomly get a blue screen of death says.
The error occurred by file : Nv4_disp
Stop : 0x000000ea (0x87E99DA9, 0x87CA2008, 0xF78C6CBC, 0x00000001)
Randomly does it, it doesn't do it frequently, maybe once or twice a day. Thing is its really dam annoying.
Comp specs are in my Signature. Nothing is oced either. And I recently formatted and re-installed windows because i thought i had a software issue with it. Runing Windows xp Home. Newest Nvidia drivers as well. It crashes only within games. never happened yet on Windows. I dont know if it could be a overheating problem or driver issue or to just Rma the card.
I do have 4 80mm fans and a 2 are pushing in from the front and one out the back. I have a Lian Li pc60. Intence gaming i get around 65-78-80 at most. I hear ppl hit 90c and thats common.
Anyone have an idea of whats the problem?
Have you tried the previous driver or just the latest? If you have anything installed in the PCI slots, try removing them and seeing it this helps, could be a conflict. You should also contact the manufacture of the video card as well to see what they recommend. You may want to try down clocking the video card 5-10mhz at a time to see if this helps and if it does, the video card may need to be returned.
XFX Support
If you've reformatted and reinstalled drivers and it still occurs, then it is most likely a shoddy part - the drivers aren't that bad.
EVGA is prety good with their RMA stuff. Recommend you go for it.
open 3dmark06, when you are rdy for start the test, run rthdribl, after start 3dmark if you have problems the video card bad, I have same problem and RMA. try
Why does everyone ask about PSU's every time someone gets a bluescreen? It has no relevance.
It's likely that it is a your video memory on your card, or your card is defective in another way.
You don't have much experience with computers do you? Of course the power supply is relevant... especially in the case of the 8800gtx...
If you have a high rated PSU of crappy quality (read: bad efficieny, unstable rails, etc) then of course the PSU has can be an issue.
