hmm after folding for 2 weeks i started getting the following this Crash
Does this mean i need to pick up a 460?
thanks for the advice,
We're going to need a few more details. And no, you don't necessarily need to replace the card. I recommend that you do not use Youtube for your technical support needs.
It doesn't have to be a G92 card for baking to work.yep looks like the cards toast.. since its not a g92 based card ya cant bake it to fix the problem..
You thought wrong.i thought it was only the G92 and older cards that suffered from that specific problem that baking it fixes?
You thought wrong.
