Hey all, its been about a year since i've posted here
, and a couple years since my last build so i'm a bit out of the loop. After researching and poking around on the forums, i think i've come to my conclusion, just need some assurance from you guys.
I think the build will look something like this, i7 bloomfield, 2.6, not quite sure on the mobo yet so i could use some pointing in a good direction, after looking at the 480's and how hot they get and the availability, i think i've backed down one step to the 5870, i'm only going to be running a 24" monitor ( which i could take suggestions on that also ). As far as the ram, some OCZ 3x2gb sticks. I already own a OCZ gameXstream 700w power supply, so that should do fine power wise correct?
Thanks ahead of time for suggestions
