Very weird problem
SkinnyBones
I was on my computer playing and then all of a sudden the CPU usage of my computer the explorer task stayed at 100%. I restarted my computer and went to reinstall windows and when i got into it the computer was showing the hard drive was unpartitioned space. Now after the windows installation copies the files over and when it restarts the first time it locks up where it says press any key to boot from cd. I don't know whats going on. Any help would be great. Thanks.
Sound's like you caught a virus that doesn't wanna leave.
If I were you, I'd download and run DBan to completely clean your HD.
I'm betting you'll have a great install experience after that. ;)
Good Luck!
