SEALTeamSix
- Aug 15, 2003
I know a lot of you guys are into quiet computers, and I found some fans with incredible noise/airflow ratios.
"SilenX fans: featuring a noise to airflow ratio no other fan on the market can touch (Papst, Panaflo and BlackNoise don't even come close!), these are the perfect fans for your silent PC. Each SilenX fan comes with silicone composite fan vibration dampening mounts, no other fan on the market comes packaged with such mounts! A 3->4 pin convertor is included with every fan.
Features:
Fan Swept Forward Fan Blade Design
Smoother, Thinner Fan Blades
Highly Efficient Hypro Bearings
Vibration Isolation Mounts"
Anyway, if they perform as advertised, they're super-quiet. Here's the full breakdown:
60mm:
9CFM/8dBA Fan $14.95
13CFM/12dBA Fan $13.95
18CFM/16dBA Fan $12.95
80mm:
15CFM/9dBA Fan $15.95
21CFM/11dBA Fan $14.95
28CFM/14dBA Fan $13.95
18 (or 28CFM)/ 11.8 (or 14.4dBA) Thermistor Fan $11.95
92mm:
20CFM/9dBA Fan $19.95
28CFM/11dBA Fan $18.95
36CFM/14dBA Fan $17.95
120mm:
40CFM/11dBA Fan $24.95
58CFM/14dBA Fan $23.95
Here's the link to the page. BTW, they ship using USPS rates. As fans go, they're not cheap - but they're worth it if you need the silence.
-SEAL
Features:
60mm:
80mm:
92mm:
120mm:
-SEAL
