Very quick questions
poach
Will a X850xt pe work with a Asus an8 sil deluxe?
Will I have problems?
What about MSI K8N platnium?
What is needed to install an OEM vid card, is it hard, I dont have very much exp?
Need replys ASAP
Thankyou
A8N SLI: Yes (PCI Express only)
K8N Platinum: AGP Only, I don't think X850 is available in AGP
You need to download drivers. Use ATI's Catalyst (reference), or an alternative; I recommend OmegaDrivers.
Yes.
Like, in general or with installation or what?
K8N Neo2 Platinum, no. K8N Neo4 Platinum, yes.
A screwdriver. Press card into slot, attach power cable (if needed) and lock down with screw. An OEM card may not have the PCI-Express power adapter.
