very quick question about ram
Xelemental
for the ram, i have just three quick questions:
does the speed of the ram have to be compatible with my mobo?
also do i need like a fan for ram?
and lastly, what pin is right for mine? i have an AMD
1. first of all -> what mobo... I see an ECS in your sig, it might be one of those supporting SDR and DDR...
2. nope - no need for active cooling the ram...
3. ...pin count? DDR - 184 pins; SDR - 168 pins (as far as I remember...)
....yes, but usually "fast enough" is the right answer. Keep in mind, however, that depending on the CPU installed, you will find the front side bus speed may be different.
....nope. Looks good, yes. Need.....not IMHO.....
Which MoBo...?? Which CPU....?? More info required.....
Cheers - B.B.S.
