Very odd video playback problem
birkski
Hi, i was referred to these forums from a friend. I would considered by self comfortable with computers, i use them a lot, but i have in no means the knowledge base of the users here. So heres my problem:
I recently switched computers (hardware issues on my old one). This computer is better than my old on in every way (quad core 2.4 gig, 4 gig ram, 512 mb video card) and I have an issue relating to video playback:
GPU is a ATI Radeon HD 3400 Series
I installed my old webcam (the settings are the exact same as they were on my other computer), not only is the frame rate drastically reduced, but the video lags behind the audio a few seconds. This is noticed when I create videos offline and on other peoples videos (ex skype) as well. Now here's the weirdest thing: if my computer is processing really hard, (ie installing something), or if i drag a window around the screen while watching my webcam, the frame rate of my webcam increases! I can think of no logical reason for this but im hoping it is possible a symptom of what is causing this.
Now if i go to my display options, and go to troubleshoot and reduce my hardware acceleration to exactly half, (the one that says i may have issues with directdraw or direct3d) it fixes it. However this not only limits my computer use to nothing involving directx, if I restart my system I get an incompatability warning from my graphics card catalyst centre and it goes back to reduced framerate (still at reduce acceleration). For it to work again i have to move the bar back up, and back down.
I've updated all of my drivers, and i've downloaded updated versions of quicktime, flash player, windows media player, divX, direct x, fddshow etc. Nothing changes. I have asbolutely no idea whats causing this.
bump, anyone have any ideas?
Also now i notice that even audio files are 'hiccuping' every 10-20 seconds. urgh i have no idea what else to try.
What webcam and what OS? You managed to leave out the two most important pieces of information. :D
O, and welcome to [H]!
Sounds like a driver issue. Please answer criccio's questions.
which ATI drivers are you using?
but like criccio ask we need to know the OS.. its the only thing keeping me from taking a wild guess at what the issue is..
Windows XP professional 5.1.2600
GPU driver version 8.513.1.0, data 17/07/2008 (says this is the most up to date)
Webcam : logitech quick cam Version: 11.90.1263.0
hope this helps.
Download the latest driver for you card straight from the ATI website, the uninstall the ATI driver again and reboot the system. Then install the new driver. See what happens.
