Velociraptor Coupon
nitrobass24
[H]ard|DCer of the Month - December 2009
On Newegg if you enter this coupon code it will give you $10 dollars off.
EMCAHABBD
I know $10 isnt alot but if your thinking about buying one it knocks a lil off.
Yes but you dont already have to be a subscriber it just signs you up. You can always unsubscribe or just the block the email.
After you sign-up, it takes NewEgg @ 24 hrs to add you to the mailing list, and you must be on the mailing list to use the coupon code.
Least, that's the way it worked for everybody I know.
