Dayaks
- Feb 22, 2012
Stop trolling us with Nvidia hyperbole. There is already a thread section for your incessant rants. (btw, nobody cares about Fiji, Kepler, Maxwell, Tahiti, Pascal, etc..)
@ Everyone else:
AMD is following a different path than both Intel and Nvidia. I've mentioned this many times and that over the better part of the last decade AMD has been in pursuance of their HSA (ie: heterogeneous Computing) for longer than both Companies. AMD has been acquiring and developing it's building blocks and it's backbone, to push their idea and vision forward. Whatever stumbling steps Intel and Nvidia are having now, AMD had 5 years ago.
As you can see, AMD has an APU, Intel and Nvidia don't.
As you can see, AMD has the One X and PS4 Pro, Intel and Nvidia don't.
As you can see, AMD has ThreadRipper and Intel is on it's heels trying to patch holes in their platforms... chasing AMD.
As you can see, AMD has EPYC enterprise chips and Intel is also on their heels, looking for a response.
AMD has their first batch of their "Secret Sauce" ready and are now tasting it on all the chips & kibbles. But Infinity fabric 1.0 technology will tick-tock in odd cadence with Vega/Navi & Zen/2.
They will advance off each other in this fashion. And 7nm Navi will make this easily known, perhaps sitting on IF 2.0.
Nothing in the Industry that AMD has done, or trying to do, gives anyone the right to demean them. You don't see Jen-Hsun Huang mocking Dr Su, do you ??
RX Vega can easily sit on top of AMD's fabric to solve many of the inherent problems that typically goes with x2 packaging. It doesn't take a brain surgeon to figure out that no matter how good Croosfire (or, SLI for that matter) really is, or was. That two side by side GPUs chips are better and cheaper and cooler than 2 separate cards. Win/Win/Win
Strictly within AMD's IP, play with the idea that AMD has fabric and could work magic with two HBCC connected (coherently) and possibly allow two GPU to share the same memory space. Thus eliminating AFR all together ?
GPU GPU
HBCC - HBCC
HBM2
It is just an idea (?).
But, no more facetious than anything anyone else has tossed up. There are endless ways to combine pieces of the puzzle. AMD Engineers have probably played with their own technology, like lego blocks playing with ideas. And as such, AMD "Chiplet" patent looks like a big WIN !
It's obviously using a more advanced form of "Infinity Fabric", as the back drop to their Chiplet design. AMD's back room is probably a mess with secret sauce splattered all over the place.
Lastly, this is a Rumor thread, but Raja did say (RX) Vega being the first to use infinity fabric on their GPUs. So even in the simplest terms, it will be better than SLI/Xfire, and I see no reason why AMD can not have their HEDT Vidcard out before xmas. I understand Nvidia's fear, because if AMD is sandbagging and fabric allows vega to x2 without afr, then you might as well nickname it VoltaRipper !!
Thanks Dr Su for thinking about the Gamer!
I would go ape shit for "Voltaripper"! How are they going to cool 750 watts of GPU though? That's around 600 amps...
Honestly I'd pay a couple grand for a seamless mGPU that acts like one.
