Vcore voltage on e6550 c2d
EnGbudd
Hi, i have a c2d e6550, i plan on oc'ing it some more but i have just noticed the Vcore is at the highest of its range. It it ok to leave it at 1.5 or should i lower it? just wondering about heat ect. Gonna try get it 3.1 ghz.
i highly doubt the vcore is really at 1.5v and the temps thats low. Anyway stock volts are supposed to be 1.32v or very close to that.
Go into bios and set it manually.
Getting it 3.1ghz will requre your fsb to be around 450. From my experience the board loses stability at 480.
