I arrived home this evening and booted my PC as I always do. Everything was working stupendously and then out of the blue, my PC's speakers began to shriek banshee-esque ear piercing noises. I immediately unplug the speakers from my soundcard and the sound goes away. However, I return to my PC to realize that it is completely frozen.
I then reboot my PC (at least attempt to) and nothing will POST. I investigate by taking off one of the sides of the case and turning it on again. My motherboard, soundcard, GPU and hard drives all load...save for my CPU's heatsink (Thermaltake V1) fan...I found this very odd. I then unplugged the power to the heatsink's fan from the motherboard and plug it into another port for the CPU fan. I plug everything back in and it POSTS now. However, as it is loading, I get a BSOD.
I try to restart again and it asks me if I want to launch Windows Repair or Start Windows Normally. I select Windows Repair and it BSODs on that giving me:
This BSOD re-ocurred nearly everytime I tried booting Windows Repair (yes, even when I tried a Repair disc I had made from Windows backup that was said to restore my system image that I save on my external hard drive. The other BSOD that occurred (that I still recall) was one saying the usual BSOD information and had "PAGE_FAULT_IN_NONPAGED_AREA" as the error.
I am currently about to run Memtest86+ overnight to see if I get any results. I have had previous hardware mishaps in the past such as a secondary drive disappearing. I changed the SATA port and updated the firmware and that has fixed it since (been about a year and a half). Last October I had my PC just randomly BSOD and refuse to boot. I ran Memtest back then and no errors came after 5 hours or so. If I recall correctly, I re-installed Windows Vista and it worked fine after that.
This is my first BSOD in Windows 7 after 9+ months of use and it saddens me greatly.
With my repair CD not working or seemingly able to load my system image as it cannot even boot into Windows Repair...is my last resort going to be to try a Windows reinstall? This will be my 4th re-format this year with all of the Beta, RC, retail, etc and I'd rather stay away from that if I could as it gets old doing it too often.
Code:
STOP: c000021a {Fatal System Error}
0x00000000 (0xc0000221 0x001003F0)
Code:
c000021 Unknown Hard Error
\SystemRoot\System32\ntdll.dll
