My housemate needs a computer. Hell primarily use it just for school work something along the lines of a grandma system, that is, nothing fancy or special.
No operating system and no software is needed. Little or no gaming and no overclocking will be done.
Hell need a screen, mouse, keyboard, etc. His desk is a bit small so Im thinking about getting an LCD screen.
I dont know his budget off hand; I assume around $800 for everything. Ill find out and post back. Im more focused on value than anything else. Ill stick with onboard audio.
Changes will probably be done after I consult with him. I havent done too much research, but heres what I got so far.
Motherboard: EVGA 122-CK-NF66-T1 LGA 775 NVIDIA nForce 650i Ultra ATX Intel
$80
CPU: Intel Core 2 Duo E4500 Allendale 2.2GHz 2M shared L2 Cache LGA 775
$146
RAM: G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
$47
Video Card: EVGA 256-P2-N541-T2 GeForce 7600GS 256MB 128-bit GDDR2 PCI Express x16
$65
HDD: WD Caviar SE WD1600JS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s
$51
DVD Drive: LITE-ON Black 2MB Cache E-IDE/ATAPI
$31
PSU: Thermaltake TR2 W0070RUC ATX 430W 115/230V
$40
Case: COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC Chassis ATX Mid Tower
$50
Monitor: Hanns·G JW-199DPB Black 19" 5ms DVI Widescreen LCD 300 cd/m2 700:1 Built in Speakers
$160
Keyboard: LITE-ON SK-1688A/B Black 104 Normal Keys PS/2 Wired Standard
$7
Mouse: Hopefully selling my old one
$20
Printer: HP LaserJet 1020 Q5911A 15 ppm Laser Personal Monochrome
$109
System: $510
System and peripherals: $806
I might just get a higher capacity HDD, because theyre inexpensive. $110 for 500GB is rather cheap, but I doubt hell use up the space.
$80
$146
$47
$65
$51
$31
$40
$50
$160
$7
$20
$109
System: $510
