Value PC Build Advice (Modified Crysis 2 $600 PC)
I haven't build a PC in years, and needed to do so on a budget. I used the Nvidia $600 Crysis 2 PC Guide as a starting point and built upon that. Any advice would be appreciated. I'm behind on hardware and trying to catch up.
1) What will you be doing with this PC?
Gaming and general computing.
$800
3) Where do you live?
California
Case, RAM, CPU, GPU, MOBO, Heat Sink, Power Supply, HD, DVD-ROM.
N/A
6) Will you be overclocking?
No
20 ish
1 month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0, SATA, eSATA (I'm uneducated on this aspect)
Windows 7 Ultimate x86 and x64
**CURRENT POTENTIAL BUILD - $726.41**
Case - Antec One Hundred Black ATX $54.99
Motherboard - MSI 760GM-P33 AM3 AMD 760G Micro ATX $54.99
CPU - AMD Phenom II X6 1100T $189.99
GPU - GeForce GTX 560 Ti
$229.99
Power Supply - Cooler Master eXtreme Power Plus 500W
$39.99 (Questioning this and considering Antec due to feedback in different threads)
RAM - ADATA XPG Gaming Series 4GB $34.99
Hard Drive - Samsung Spinpoint F3R
$74.99
Heat Sink - Cooler Master Hyper 212 Plus $29.49
DVD Drive - ASUS Black SATA DVD-ROM
$16.99
Don't go with that setup at all: It's just not that good for the money. I recommend this setup instead:
$225 - Intel Core i5-2500K CPU
$133 - MSI P67A-G45 Intel P67 ATX Motherboard
$65 - Kingston KHX1333C9D3B1K2/8G 2 x 4GB DDR3 1333 RAM
$185 - eVGA 01G-P3-1460-KR GeForce GTX 560 1GB PCI-E Video Card
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$20 - Sony AD-7260S-0B SATA DVD Burner
$90 - Corsair 650TX V2 650W PSU
$55 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
Total: $833 shipped
Those are Amazon.com links as I highly recommend that you buy your parts from Amazon.com since they do not charge tax to California residents. Newegg does charge tax to CA residents.
Anyway, the above build is superior to your planned setup in virtually every way except for the HSF. However since you're not overclocking, the stock HSF that comes with the CPU should be fine.
