UV Modding Safe?
Xplod
I was thinking of building a new system using a UV sensitive Acrylic case and UV sensitive components, but keep seeing these warnings about EMR and so forth. So is this going to kill me or cause me to grow a third arm?
Sorry EMR? That's a new one on me.
Anyway, everything I've heard says that UV is harmless with one important exception. If you have UV leds, it is best not to look straight into them because, so I've heard at least, your eye does not recognize how bright they are. This means your pupil does not adjust properly leading to potential damage. This GENERALLY doesn't apply to other sources of UV because they are rarely strong enough to cause significant damage but UV leds can run in the high mCDs.
Just wire all your lights to a switch and control the use of the lights.
i believe the UV radiation from the sun is comprised of 3 different wavelengths? uv-a uv-b and uv-c ... i believe a cathode is emiting uv-a and that isn't going to give you cancer.
http://www.icnirp.de/documents/uv.pdf
http://www.ciesin.org/TG/HH/ozhlthhm.html
though i'm just thinking of the top of my head ... so don't quote me on this.
i'd just do some research and i'm sure you'll come up with some definate answers. write the company that makes the cathode.
Most sources agree that the UV CCFL lights are not dangerous. The majority also agree that gazing into a UV LED is a bad thing. Personally, the array of EM fields that we are exposed to and the amount of time I spend near computer equipment would make my use of any UV stuff only temporary. Safe in low doses doesn't mean no third arm a few years down the road.
o well... maybe i'd like the third arm :D
ooo just tink of the possiblities!
i have over 8 UV lights in my comp.. no problem at al
