Sixthsense
I Suck Fat Ones
- Apr 15, 2001
Well im buying it for PC, thats the only true way to play UT3
both should be pretty similar consider both will have M&KB support and mod support. PC most likely better graphically though, but that will probably cost more money.
Well, I said I'd get it for the PC in another thread, but I'm thinking... it just might run better on my PS3 (see my PC specs below).
There's always the option for a FragFish for my PS3 so the kb/m argument is out of the window...
Hmm...
UT3 is supposed to have KB/Mouse support on the PS3 anyway.
How often do you hook your console up to a computer monitor though? You going to play with KB/Mouse while using your TV? Maybe I'm in the minority here but I generally play consoles on my TV while sitting on my couch.
Buying this for anything but the PC if you have a rig that can play it respectably is crazy anyway
A UT game on a console just won't be as good, whether its the ps3 or the 360.
+1![]()
Anyways, if I got UT3 I'd get it for the PC because you can customize the graphics. I haven't seem too much FSAA on PS3 yet, but UT for XBOX1 was probably one of the few with FSAA.
Getting this one for the PC thats for sure also. Unreal Tournaments were always the best on the pc. Mods, Maps, and all types of stuff is what i am looking forward to also. When it comes to fps, the pc rules in that category. Without the user created content the game would get old after the regular content got used and abused. Atleast sony knows the pc's strong point and supports pc to ps3 content. Not so sure though if any of it would be compatible lol.![]()
Not holding out for the Wii? J/K![]()
All the time![]()
This month's magazine of EGM states that Sony's PS3 does not run UT2007 engine very well and that Sony is tipping Epic a "money hat" to ensure it works well on the PS3 by the time of release.
Yes.The PS3 will accept a bluetooth keyboard and mouse though right?
time to clean up those finger marks
http://www.n4g.com/tech/News-51800.aspx
The only game i was able to play against a consoler was Quake 3 in like a 1.16n version or something like that. It was pretty fun. Owned all the dreamcasters before the dreamcast servers went down.![]()
