I know it's Tom's, but I found this very interesting.
I'm planning on a RAID5 array, but I'm on a tight budget and this could save me $200 on a controller card. My array is for one computer and would only be used for storage of music, movies, etc so speed wouldn't be a big issue.
However, keeping my data safe is important, and running my array off a hacked version of Windows makes me a little learly.
Thoughts?
edit:
If anyone is wondering what's going on, I posted a link to a guide on how to use Windows XP to setup software RAID5 and Douglite, a new moderator, decided to remove it 4 months later.
If I had known the link was against forum rules, I would not have posted it, and would have removed it myself had anyone asked.
If anyone wants the link, I suggest you try seaching www.google.com , and if you're not smart enough to find it, you shouldn't be messing around with your registry anyway.
Thoughts?
edit:
