Using multiple mice with mouseware
DeeJay
Hi,
I have the logitech MX700 and the MX510 mouse, both of which are connected to the usb port. But only the MX700 mouse is shown in mouseware. That means that I cannot configure the MX510 mouse. Is there a way to get them both to work with mouseware?
There should be no problem using both. I don't have the same setup as you, I have the MX700 on the USB port and a Trackman Marble+ on PS/2 but have no problems using and configuring both.
There should be a drop down menu or something that will allow you to select one mouse or the other to configure it. Look to see if you can find it. I'm at work so I don't have a way to check to see where exactly in Mouseware the dropdown menu to select is otherwise I'd tell you.
The MX510 requires it's own software so I don't think it works with the MX700. I've got a MX500 and MX700 hooked up and they work fine together. I tried 2 MX500's but it didn't work.
I downloaded the new mouseware and now it works fine. It appears that the old mouseware simply didnt support the MX510
