Hi
I want to use 3 IDE devices on a normal IDE cable. I have added a fourth IDE connector on the cable.I want to switch between HDDs using a DPDT switch to switch the power between them. So I would have
Mobo -> DVDROM -> HDD1 -> HDD2 on the IDE cable. Only 1 HDD would be powered at any one time and all devices are se to 'cable select'. THis works well until I want to use the DVDROM.
Booting from either HDD works fine - but using the DVDROM is cannot read most disks and stutters saying the disk is damaged etc. Unplugging either of the HDD from the cable and the DVDROM is fine. Obviously this is the root cause of the problem - is this a resistance problem, I am using 40pin IDE cable is this the problem? Anyone else hazard a guess? Using 'master' on the drives also does not solve the problem.
Thanks
Thanks
