I have extra ssd (M4) , so maybe I buy external enclosure to use it for data storage, is it good idea ??
Or ssd only meant for OS , can trim still pass if it use as data storage drive ?
how about if I connected to SATA III and use as data storage drive, will TRIM work, thanks
Personally I wouldn't bother with using a SSD as external storage since it really isn't that large compared to HDD, but I would throw it in a PC even if there is a SSD installed and use it store frequently used Apps and games if you still have room in the case. BTW, how large is that SSD?
Why not? It depends on what he wants to use it for... Let's say for instance he just wants to carry around a couple movies in it, it'll be much much quicker to transfer them to a SSD on a USB 3.0 enclosure than to any hard drive, and the SSD will be smaller and less sensitive to constant traveling as well. Now if he needs a lot of space and it's a small SSD, then yeah, external data drive isn't the best use of it.
Isn't that what AHCI is for? Keep your side panel open (or pull some cables through the back), plug in some random sata cable and a power sata cord. eSATA even simpler. Don't even have to restart right? Why would you prefer usb over that...
It'll only be as quick as the slowest drive, so unless he also puts movies on an internal SSD...
