USB traffic causing mouse lag?
RyanH
I just recently purchased a 1TB WD My Book Essential Ed. Ext. Hd and have it hooked up to a USB 2.0 port on my PC. I also have a USB 2 Logitech G5 mouse and G15 keyboard as well as a USB 2 mic all hooked up to USB 2.0. ports. It feels like my mouse isn't as responsive as before I installed the HD, and I'm wondering if it could be because the mouse data transfers are getting slowed down by other USB transfers from the HD. I have the latest Logitech drivers installed and I increased the polling rate to 1000Hz and I have my Mobo updated with the latest chipset drivers and BIOs version too if that even matters. In the BIOS i have the USB host controller set to Hi Speed. I was transferring a bunch of media files over to my new HD and noticed the transfer rate was only about 25-30 MBps, Im wondering if all my USB devices are taking up too many resources, or if theres a way I can monitor USB traffic. Is there any way I can set my mouse to a higher priority as far as USB resources goes. The PC im using is in my sig and my Vista is fully updated.
Hi speed just means USB 2.0, instead of forced 1.1 only.
How about empirically? If they all run off of a hub (internally or externally), then it could definately slow it down.
