NeghVar
- May 1, 2003
If I plug in a USB hub to a USB port which is bridged to the VM, will all the ports on the hub be part of the VM too?
For USB devices that you need to connect to VMs I highly recommend this solution: https://www.digi.com/products/models/aw-usb-2
I get no compensation for this, just something I have used on several projects.
For ours we wanted our badge system to be a VM rather than a physical box however it required a USB authentication key to allow use of the software, we did USB passthrough accordingly.Wow, thats kind of cool you can do that, never thought of doing that. What is the use case?
Just keep in mind with passthrough it's assigned to a specific VM, and depending on your VDI infrastructure may not assign the same VM to the same user each time (or is yours small enough you have dedicated VMs to dedicated users?).
