Kil4Thril said:I guess I should be a bit clearer. I want to use the flash instead of disc to install WinXP. It should be MUCH faster than reading from disc, and I can install to systems (tablets, laptops, etc) that don't even have opticals.
djnes said:In that case, it might work, as simply as making a USB drive bootable to a DOS prompt and running the install from there. However, it's still not going to run very fast. I see your point about computers without optical drives, but I think I'd prefer dropping a sysprepped image onto those machines from the network.
nessus said:I'd use the USB key to boot onto the network to pull the image. Definitely faster than using the key to pull the image. (I'm on GigE.)
I get faster throughput using the Windowx XP stack instead of just DOS, although it is faster either way.
You could easily do a BartPE bootable USB stick with a directory to install XP from on a 1 gig memory stick.
dbwillis said:Theres a how to over on the NU2 site (BartPE site) on how to get it onto a USB drive, I havent had much luck with it,,,yet
bbz_Ghost said:The second one there is titled:
"I successfully installed xp from a USB hard drive"
and while that's relatively easy to do, installing from a USB Flash drive isn't the same thing nor is the process quite as simple just because it's a different type of media. The procedure most like works (I've tried it, never had any success) and I'm still looking for an absolutely foolproof method of taking an XP SP2 CD ISO and transferring that directly to a USB Flash drive for use as an installer - meaning the CD is no longer necessary.
Sure, it's possible to copy all the files off the CD to the USB Flash drive and make the Flash drive bootable using some 98SE boot sectors, but that's still not the same as booting off the USB key itself and going right into the installation exactly as you would if you were booting off CD.
I don't think it's possible to do what I myself and many other people would love to do, but it doesn't hurt to dream I suppose.
I've got a 4GB USB Flash drive that I'd love to slap Vista's DVD image on and do some install speed testing, but it just doesn't work that way.
