USB 3.0 PCs Coming Soon?
HardOCP News
[H] News
According to this article, a “number of people in the industry” say that USB 3.0 equipped PCs will be shipping by the end of the year.
SuperSpeed Universal Serial Bus (USB), better known as USB 3.0, is about ready for commercial rollout as the next-generation USB interface. At the SuperSpeed USB Developers Conference held in Tokyo May 20-21, 2009, it became clear that industry is pushing ahead fast with the development of compliant integrated circuits (IC), instruments for equipment developers, and more.
USB2 has a practical transfer limit in the low to mid 30-something MB/s range. Even a 33MHz PCI USB3 card would more than double that and more likely nearly triple that. A PCIe x1 USB3 card could handle near native speed, for one device at a time at least.
Capacity Per lane:
v1.x: 250 MB/s
v2.0: 500 MB/s
v3.0: 1 GB/s
Not even PCI-E 2x is enough... We're screwed =/
Capacity Per lane:
v1.x: 250 MB/s
v2.0: 500 MB/s
v3.0: 1 GB/s
500 megabytes or megabits?
I just found this:
USB 2.0
Added higher maximum speed of 480 Mbit/s (now called Hi-Speed)
60MB/s? (1 megabyte per second = 8 megabits per second)
A new major feature is the SuperSpeed bus, which provides a fourth transfer mode at 5 Gbit/s. The raw throughput is 500 MByte/s, and the specification considers it reasonable to achieve 400 MByte/s or more after protocol overhead.[
USB3.0 is "up to 5 gigabits/s" maximum (on PCIe 2.0), matching the data rate available on the PCIe 2.0 x1 slot.
You will run into far more practical limits before that on almost any device that will be plugged into USB 3.0. Hard drives (eSATA would be a better choice for the fastest SSDs) and 1Tb NICs should be fine.
Of the 480Mbps available, there is also protocol overhead above the data payload and also packet timing limitations. Without packet timing bandwidth losses (not realistic in actual use), the maximum bandwidth available is ~40MB/s for a bus with no shared devices. In practical use, maximum bandwidth is about 10% or so below that.
Lots of P55 boards have USB 3.0 on them. Check out the pictures. They have a very slightly different look to them, and are backward compatible with 2.0 (still have copper in there).
usb 3.0? heck, everytime i hook something up it tells me it could be faster with 2.0 or something, so i guess im still stuck on the old regular usb.
i would love to have a faster usb interface. no way in hell im buying a motherboard now, my next one will have usb3.0 as a must.
Is there still room to expand to USB 4 in the current plug? Will USB 4 ports be compatible with 1.3, 2 and 3?
ask again in 3=5 years when hardware engineers start thinking seriously about which of the new shineys in their toolbox can be put to use on the next spec.
Hell I'd be happy enough if it was just twice as fast as USB2.
thats what im saying. it seems like a lot of people think usb2 is fast... to me, your cable connections should be transparent to the device's bandwidth... wont it be nice to burn blurays at 8x speed on a simple usb3 connection? there is going to be a huge desire for faster speed within the next few years
Therein lies the rub. If it was only twice as fast as USB2... it would still suck.
Consider this, for example.
I have my laptop. It has USB2 plugs on them. 4. Some devices need to be plugged directly into a USB port to reduce or eliminate any issues. Some just outright hate hubs. So I tend to keep 'critical' devices plugged directly in (DVD Burner, external Hard Drives) and leave the rest to the hub.
Well, I added another hard drive to my setup and putting it through the hub was killing any speed I could have gotten with it. So I was checking out options to allow myself another USB2 plug for the new drive... (2 500GB, one mirrors the other, DVD Recorder and a 250GB drive, the new one. No plugs left for the hub which does my mouse, keyboard, printer, thumbdrives, cooling fans, etc) (Firewire400 was an option, but I did not want to buy any new enclosures to replace the ones I already had)
I have a PCMCIA/CardBus slot on this laptop, so I could have gotten a USBx2 card and stuck it in. Both of my 500GB drives, however, are in USB2/eSATA enclosures. Checking prices out, reviews (not a whole lot), I decided to take a gamble and buy a Rosewill eSATAx2 Cardbus card that was on sale at NewEgg and give it a shot.
My impression?
USB *really fucking sucks.*
Holy shit, man. I'm tripping balls just over how horrid USB2 really is.
500GB Seagate Barracuda 7200.10, 7200 RPM, 32MB Cache, SATA2 drive. Same bridge/enclosure for both tests, so no bias there.
USB2 mode gets me 29MB/sec burst, 27.1MB/sec average.
PCMCIA/CardBus > eSATA gets me 70MB/sec burst, 61MB/sec average.
The USB2 test was performed with *no other USB devices attached*, not even the hub.
In this situation, the bottleneck is the CardBus interface. If USB3 was only twice as fast as USB2... it'd still be slower than a bottlenecked PCMCIA/CardBus connection.
No thanks.
Now imagine eSATA when it's not going through a CardBus slot.
CPU Utilization was also surprising.
USB2 ate up 12-15% CPU,
eSATA through CardBus was <1%.
Needless to say, I happily use and back up my eSATA connected 500GB drive more often now.
Amusingly, with both 500GB drives connected to the eSATA CardBus card, mirroring the drive was slower than having one connected by USB2 and the other by eSATA. Lost my figures for those, but it was roughly 120 minutes versus 190. So yeah, the CardBus interface (probably just PCI) was saturated by one drive.
Finally the times has come, USB 2 is getting old. 3.0 should be quite nice for many devices for some time.
yeah but the next spec of firewire is due pretty soon, if USB3.0 hasnt done anything about the overhead of USB, then it will still get blown away by firewire, which will itself be blown away by Sata III which is also nearing release isnt it?
i need faster USB. its my current bottleneck when transferring files from my file server to my computer.
Usb3 should require a dedicated chip so cpu usage wouldn't take that much a hit.
USB3.0 isn't anything like USB 2.0/1.x. Even the socket has 2 sets of connections, one for USB3.0 (5 pin) and another for legacy USB (4 pin). USB3.0 is "essentially PCI Express over a cable."
Even if USB 3.0 was as inefficient as USB 2.0, it would still deliver a maximum of 4Gb/s bandwidth. S3200, if it lives up to it's performance promise (97% of 3.2Gb/s), tops out at 3.1Gb/s. I would expect a non-crummy implementation (cough not VIA) of USB3.0 to easily outperform S3200.
Oh I agree. It would just suck less though. I never hope for much, saves me getting dissapointed.;)
I've done all the PCMCIA/Express slot SATA/eSATA cards and while they are fine you cant always use them on clients equipment.
So like I said if USB3 was just twice as fast as USB2 in reality I'd go with that.
Everyone else seems to think this might actually achieve more than 20% of its theoretical performance. Hmm I'll wait and see.
Usb3 is implemented independently of the legacy 1.1/2 interface, and uses the same type of cpu independent data transfer than firewire or various internal PC busses use.
I'm not excited. The only reason I would prefer USB 3.0 would be for 2.5" USB-powered hard drives or really fast flash drives - neither of which are very important to me in terms of speed. USB 3.0 still won't provide 12v power so that I can run 3.5" drives without a brick, so there's no advantage over eSATA for external disks except for compatibility. The vast majority of my USB devices can't exceed USB 2.0 speeds.
For your own systems, like at home, you can buy a bracket with female molex connectors on it so you don't rely on a power brick for external 5v/12v powered drives. It comes in handy for USB connected IDE/SATA drives too.
http://www.svc.com/ok302.html It's probably cheaper after shipping on monoprice if they carry something similar, but I couldn't find one besides an IDE/molex bracket.
I don't mind having a power brick too much; it's just that I think 12v power would be a nice advantage over eSATA - just plug in a single cable and not worry about the proprietary power jacks on external enclosures. It'd be a good way to go if you don't mind sacrificing speed for convenience.
Then again, it'll further encourage the design of USB-powered fans, beverage coolers, microwave ovens, and other general crap that shouldn't be powered over USB to begin with.
