USB 2.0 headache... what gives?
noobtech
Okay, so i'm currently running an Athlon X2 6000+, MSI K9A2 Platinum Ver 1 mobo, Raptor, 3GB DDR2-800, Vista 64 and I know my USB isn't running at 2.0 speeds... i've uninstalled and reinstalled drivers, checked cables, even went it and saw it said USB enhanced, but that's only in one part... when I plug in devices that are usb 2.0 capable, it says plug into a usb port with 2.0 for faster speeds.....
I'm so lost... I'm tired of uploading 2gb of photos or updating my iphone, only to wait up to 30 minutes for transfers...
I have read and searched so many websites for help, but I can't find a way to fix it...
You've installed all windows updates? USB2.0 drivers are provided by Microsoft. There may be an incompatibility between the MS driver and your board, but I doubt it. Did you ask MSI for help?
When it happened to me I spent a week trying to figure it out. My fix was wierd- I had went into the bios and set the mobo to default specs. Solved the problem.
I never did figure that out when it happened to me and IIRC, I did an XP repair install for a fix.
I read somewhere it was because one of my cables were installed wrong on the USB 2.0 plug ins with my Lian Li V1000 Case... the front USB connector was setup differently? I ended up just re-doing my entire system and not plugging in the plug, but i'm sure I could of figured it out the other way...
Anywho, it was a good time for me to redo my system since I was using a 74gb raptor drive that ran out of space as soon as I installed Vista on it... LoL... I ended up getting two WD blue 500GB drives... not in Raid. =)
The 640GB drives would have been a slightly better option, as they use higher density platters, which makes them a bit faster.
Anyhow, I've had a case where the damn wire connections were labeled wrong, which made me plugin the front USB incorrectly... luckily, I guessed the correct pinout of the front ports and got them to work finally, lol.
I find it a bit difficult to find or understand the differences or wondering how many platters there are in the hdd's... I just go by ratings and sometimes people might mention the differences. I just can't wait for Solid State drives to come down... like 1TB solid state for 50 bucks... that would be awesome. ;-)
