GreenArrows
- Apr 2, 2014
Hello
I purchased a Dell UP2414Q from the states. I have a UK to USA plug adapter, on the face it says 250V 13A, inside the up2414q box dell provide a cable that connects the plug to the monitor which has a sticky label saying 125v 10A.
I am curious because my outlet provides a greater volts/amps, perhaps the monitor can get what it needs and will work, on the other hand perhaps giving it too much will damage it?
I phoned dell tech support, and they said that I should just buy a dell UK cable which will be 250V 13A, if this is true then it seems to me like the monitor can handle a greater Voltage/Amperage, however some tech support don't know what they are doing.
What do you think? Thanks
