Urgent Problem -- Computer Wont Turn On!
xWhiteboy55
Hey everyone, tonight I was just on my computer regular when all of the sudden it just shut down. And when I went to turn it back on nothing happened.
Everything externally is plugged in, Im not to sure about the internals though.
Im hopping I didnt blow a powersupply. Its a 250w "power win"
Please tell me what the problem could be. It has to be something not plugged in right?
250watt Power win...
I dont even want to ask why you are using that....
PC power and Cooling please
More than likely that is your problem is your crappy PSU...
It depends on what he is running. 250W might work fine for an old P3 600 or something :). Why spend $150+ on a PCP&C PSU when the computer is worth less than the PSU :p
hmm, Its not the PSU. I found out what it was when I opened the case.
One thing I thought I included in the post was that I knocked into the computer. What I did was I knocked one of the rubber risers out from under the motherboard. The computer is in pieces now and im trying to fix it back up.
The specs are this
P4 2.4 processor
512 sdram
9200se Radeon 128mb vid card
elite group mobo
