Urgent - P5K deluxe RAID support
Val
Stupid situation... I was under the impression that all "Deluxe" motherboards are ICH9R, so they support intel matrix raid.
So i ordered one of those. Then today, when it has already dispached, i called the shop (overclockers.co.uk) and asked about the raid support. The shop told me that it does not support raid, since its a usual ICH9 chip, not R.
Am i screwed?
Would appreciate some quick answeres, since i need to order some RAID ASAP controller if i am... :(
Best thing to do is check these things out by searching for the answers at the manufacturers website.
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=534&l4=0&model=1646&modelmenu=2
I have actually used the P5K Deluxe WiFi-AP Edtion, but the non-WiFi version shouldn't be any different and according to ASUS' site it isn't. Their page clearly states there is RAID support for this board. I can also confirm that there is indeed RAID support present from both the ICH9R and the JMicron controller's that are integrated into the board.
My board is actually WiFi... Yep, also checked the ASUS website.
But the guy in customer service was very determined:
- Just to confirm that the boad i ordered has raid support.
- Nope it doesnt.
- You 100% sure?
- Yep.
- You know what im talking about - two chipsets, one is ICH...
- Yes, yes. The one you ordered is ICH9.
- Are you absolutely sure about that?
- Yes.
So that got me worried a lot :eek: Anyway, im pretty sure that its ICHR now, since you used it :) Thanks for help Dan, that lightened me up a bit...
- Nope it doesnt.
- You 100% sure?
- Yep.
- Yes.
You're welcome. If you have the P5K Deluxe WiFi-AP Edition, you've got no worries, all of it's SATA ports are RAID capable. I've even done RAID testing on the eSATA ports.
suggestions and tips.
Load the preinstall (F6 floppy) drivers for both controllers during windows install. Its easy and if you dont do it now and decide you want it later, its a pain.
The intel driver for RAID include AHCI with support for NCQ etc etc. so you get all the SATA goodness with RAID selected for the controller in the bios.
Same with Jmicron.
Download latest drivers dont use the ones on the CD.
Do not let windows update ever update the drivers for your drive controllers. Go to the manuf or Intel or Jmicron web sites.
The raid 5 supports a max of 4 drives, thats it, no more.
Enjoy.
- Nope it doesnt.
- You 100% sure?
- Yep.
- Yes.
This person doesn't have enough knowledge to be a support person. The Deluxe has the 9ICHR chipset, not the plain 9ICH. I would bet he might say that the P5B Deluxe doesn't use the "R" chipset either. Technically, I think this shop should fire him. Or give him the proper update training so he won't give out false informations.
