Spartan611
- May 7, 2006
Hi guys. I am typing this from my desktop just for reference. I have a Macbook Pro with a 2.4 ghz Core 2 Duo and a 8600M Video card (for reference on what model the laptop is) and am running Leopard and Vista in Bootcamp. I use it for school (for some programs like Office 2007 and others, although I am aware Office 2008 just came out). It has been running mostly fine since the Bootcamp Beta with Tiger. Now I had Windows Live One Care on this computer and that computer as my antivirus. And it expired on 2/1/08 on both computers. I uninstalled it on this desktop with really no problems. But I installed Fix it 8 Professional before the expiration date on the license on the laptop and thought I disabled Live One Care. I should know better that having 2 antivirus programs can be bad? But what happens if only one is for viruses and the other is like tune up stuff? Anyways for some reason yesterday (it when I first noticed it happening) a lot of Windows Vista is messed up. Here are my problems:
1. Windows Explorer is all messed up. I can only open some folders and stuff.
2. I cannot open the Network panel from the Vista start menu shortcut.
3. It shows my network is disconnect in the bottom right permanent task bar even though I can connect.
4. I cannot uninstall Live One Care. It stalls and then crashes (That is why I think One Care may be the problem).
5. I cannot update my Fix it Utilities 8 Professional Virus Definitions in order to run a virus scan.
6. Multiple programs stall, hang, and crash.
7. I have encountered Blue screens before this problem and during the last 2 days.
8. I ran Reliability and Performance Monitor as well as the Task Manager and both show my CPU running at near 100%.
9. I cannot enter the windows update screen (the view already installed and the check for updates) window.
10. The computer is very slow.
I need help with this guys. What do you guys think it could be? Virus? Hardware Error? Registry or Software error? One Care error?
I dont want to reformat the system because I may have some important files. But at the same time I cant backup the files because they may be infected.
Does anybody have an idea? Please respond ASAP. Thanks for the help guys, I really appreciate it!
EDIT: I should add that all this is happening on the Windows portion. Forgot to mention that..... oops.
